mbrooke
Batteries Included
- United States
- Technician
wrong
wrong
Explain.
by definition it does not
Define
V source = sum(Vloads)
the potential is across the source and loads, not the neut
And what is load hooked up to?
wrong
wrong
A neutral point does not have to have balanced protons and electrons in it. Let X have balanced charges, Y have one excess positive charge and Z have two excess positive charges. Y is the neutral. X pulls on Y in one direction just as hard as Z pulls on Y in the other direction. The neutral point is where the pulls (charge imbalances) all cancel each other (equilibrium point).you have negative charge (excess electrons) or absence of electrons, holes or net positive protons
or no net charge, balanced or 'neutral', ie, protons=electrons natural state
15 kv triplex shielded cable 1000' feet long
laid on ground
in service, then disconnected, will it have a charge for a period of time?
Think zero sequence current for a moment...
Yes- but the same thing is happening in two or three separate winding- just out of phase to on another.
In a perfect system with a zero Z noodle- come reality a neutral carrying load will always measure voltage to ground because it will always have impedance to some degree or another. Granted this concept is drifting away from the topic at hand- but you used it as an example to support zero charge which I disagree with.
If not at the right point in the sine wave certainly yes- due to capacitance.
Neutral in charge for the object, not that it sits at an equilibrium point in space.????
open ckt
touch h-g
touch n-g
is the a difference?
is g/earth considered 0 potential?
Electric charge is the physical property of matter that causes it to experience a forcewhen placed in an electromagnetic field. There are two types of electric charges: positive and negative (commonly carried by protons and electrons respectively). Like charges repel and unlike attract. An object with an absence of net charge is referred to as neutral.
has nothing to do with it
of course, that is kind of the whole point
does not matter if you agree
it is fact, the neut in theory has 0 potential
Vsource = Vload
no neut involved
the source produces work/emf, the load absorbs it
N-G is not germane to the neutral point discussion. Earth is a different topic.Always do- yes- the second one. Current can not flow without voltage.
Take a volt meter L-N- does it not read 120 volts?
N-G, Unless there is no load, there will be up to a few volts potential due to the voltage drop across the neutral.
But going back- if the neutral has no potential as you said, it could not read 120 volts, correct?
ALWAYS will
it's a dc charge
does the unconnected for weeks 14 awg on the floor have charge?
Explain.
Define
For the neutral point, what doesn't cancel moves the neutral point. In other words, the charge imbalance on the neutral point will be such that it is at the equilibrium point of all the forces acting on it.What I was trying to say- but you said it better then I ever could![]()
And what can't cancel, goes back to the source it originated out of- correct?
Then how do equal loads cancel current out in the neutral?
Maybe we can agree here.
Yes- for a perfectly balanced system as measured across the neutral. But as soon as I take a meter or wiggy L-N that ma leakage shows otherwise.
think about it
what comprises 'charge'
I did, you cut it out
an emf source
Say X is Earth (or a grounded conductor). Increase the charge imbalance at Z twice as fast as at Y (or let the the Z to X voltage be twice the Y to X voltage). Where is the neutral point for conductors X, Y, and Z? It is at Y even though Y has a charge imbalance.that is called the 'neutral'
I have no idea of what you are trying to illustrate
what are X, Y and Z?
it better net 0
because if the charge entering does not equal that leaving we have an issue
unless you are charging something
