mbrooke
Batteries Included
- United States
- Technician
If there is voltage drop on neutral (which there is if current is flowing) then there will be neutral to ground voltage and current will flow during a neutral to ground fault. If you are in that current path you want the GFCI to open the neutral to stop that current.
Majority of incidents neutral to ground voltage is minimal and unnoticed. Get around a swimming pool, hot tub, etc. and suddenly everything around you is conductive enough to be dangerous with even that minimal current.
Yup! And broken skin can make it even worse.
