MrMilbank
- between LB and Head
I'm 25. you old folks sure do bicker allot about wiring methods. speed + code compliance + clean trucks = my work ethic.
Here is yet another perspective.
We are currently building 3 identicle 35k sq ft. facilities, three different regions with three different contractors. All of their bids were very close to one another.
Prior to the bid process there is never discussion of " down and dirty price" or "art work price". ( I realize this does happen on some small jobs) It's just assumed best price for a quality installation.
As the projects are all nearing completion we are seeing quite a "quality" difference between the three. The contractor that has taken the time to do a top notch job will be added to our preferred contractor list. The one that has run his MC so it looks like a rats nest, has sloppy panels and has cut corners at every chance probably won't be used again.
I guess my point is people DO see things in the walls and ceilings before they a covered. Sometimes a little extra effort to be neat might get you that next job.
An interesting side note is the standout companies foreman is about 55 years old.
The not so standout foreman is probably 30.
you can be code compliant and still be sloppy ,code is MINIMUM standards."neat and workmanlike" can be inforced its known as "you'r fired"
I have to agree with this.You're fired would solve a lot of the sloppy work.
I under stand that it can be code compliant and not be a neat install.
This is where pride in workmanship has went down the tubes.
But Cheap people are the cause of the poor workmanship.
Cheaper is seldom ever better, Cheaper usually leads to sloppy/non code compliant installs. The E.C. has to take to many short cuts to survive.
...Why not shop for quality in the first place?
