Extension ring... wiremold ext. namely is not that atrocious esthetically
....Or, you can also (depending on the circumstances) nipple out of old panel to new box/ afci/gfci receptacle underneath panel-run wire from old breaker to that, then refeed old branch circuit from new receptacle.
This works for device replacement also b/c of 406.4(D)(4)(2).
looks like NEC is dicated under a fire trade association. why is NEC not under FEMA, or IEEE, or a NEPA ???
the NEC is written under NFPA code # "NFPA70". there is no NFPA code # titled "NEC", the name assigned to NFPA70 code is "NEC"
the NFPA has hierachy; CODE#[name]
http://www.nfpa.org/codes-and-standards/all-codes-and-standards/list-of-codes-and-standards
NFPA 70 IS the NEC.
The NFPA is not written by fire fighters-
Its simply an organization which, thru a consortium of individuals representing different trade groups (insurance companies, engineering associations, etc.) develops codes and standards for all kinds of stuff
Other examples of codes they produce...
NFPA 72- fire alarm code
NFPA 70b- code for electrical maintenance
NFPA 54- Natural gas fuel code...
And iirc they are responsible for something like 200 different codes accross different trades/industries etc.
