Did you make it like a sticker? Something you can buy from the office store?
Avery No. 5265 labels..... 8?x11", then cut them to size.
Copper SEU cable? That's hardcore.![]()
One thing that helps minimize the end-of-the-can traffic jam is to bring the wires in on the same side of the panel they'll land on, or alternately, land them on the same side as they enter the panel.I much prefer to install a panel with the lugs top or bottom depending on the direction the feed is coming from, but as you can see and surely experienced with main on the bottom it crowds the circuits coming in from the top.
One thing that helps minimize the end-of-the-can traffic jam is to bring the wires in on the same side of the panel they'll land on, or alternately, land them on the same side as they enter the panel................
That's actually blue Sharpie ink that got partly worn away from handling. The picture makes the white appear much brighter than it really is.What's with the green/white wires on the breakers?
They came in the panels. I always remove and save the ones I don't need to use. I store the mounting screws in a couple of the wire holes.2 ground bars? never seen it in my life![]()
