Are you guys serious? Of course I know that wire nuts make the bulk of splices, where did I say solider is still common? :blink: Talk about jumping to conclusions. I only mentioned crimp/solider connections because that could have been one of several dozen listed alternatives where an electrician can pick and choose. The NEC lets you use an outlet AFCI if the home run is conduit, doesn't mean conduit is mandatory or common in home wiring. The NEC still allows fuses, if I mention that here do guys automatically assume Im saying that fuses are still used new dwelling construction instead of breakers?
Second, ask the British and others what they think of wire nuts :lol: Dont get me wring I use wire nuts, but some guys misuse them.
Your right that you never said solder was still common. I was only trying to explain why it would be impractical to to revive two time consuming, labor intensive and(thankfully) obsolete ways of terminating solid cccs which, btw, when applied correctly would provide no additional benefit against series arcing vs. a modern wirenut applied correctly. In residential time is money and while backstabs need to get the boot, the quickest cheapest way of getting things done is always going to win out and bcaps fit the bill when paired against a method that conjures up images of Tony Bennet's heyday, Falstaff, and a pack of Luckies.
