He is saying even those that care can make mistakes.
And he is absolutely correct.
And he is absolutely correct.![]()
I care yet I have made my share of mistakes.
That is what is known as an opinion, not a fact.
So you feel only electricians do wiring in homes?
Wait, so now your telling me we need all these extra code mandates? :?
iwire was only interpreting (correctly) what templdl pointed out. And there is a lot of truth in what templdl posted-basically no matter how careful you are (or looked at another way no matter how many nec mandates are in place) mistakes are going to be made. We cannot eliminate risk in this trade now matter how many contingencies we put in place.
But should code try and mitigate that risk? And to what extent?
Yes, it should but only to a reasonable extent.
My personnel belief is before the NEC mandates anything we need to have an unbiased source investigate the exact cause of dwelling fires in meticulous detail. At this point we having nothing but assumptions about fire statistics.
To detect 'glowing connections" in my opinion from a remote location such as would be breakers or fuses would pose to be a most difficult task. With breakers or fuses they are monitoring the current that passes through then. They have no idea of the load that they are serving. Isn't a glowing connection basically a resistive load in series with the load? That if there was no load there would be no need to pass current through a compromised connection unless it was a unintended connection between the L-N or L-G.
What type of glowing current would even cause a breaker of fuse to respond to a glowing connection when both devices are respond to a given TC curve?
Besides the GF feature the intent of the AFCI is to recognize snd respond to the erratic current nature of an arc fault, either series are parallel, which most if not all of use have concluded is a fallicy.
Personally I do think the the common branch circuit breakers of load centers be given a second look and not accepted the way they presently are. Because the manufacturing costs is extremely sensitive, I used to know what the actual costs were years ago, it is dirt cheap. It is a given that those breakers must be manufactured with a bimetalic element that trips the bresker is calbraterd to match the tasting of the breaker. However, the mag/instantaneous element is not. If I can recall, the only difference between 15, 20, and 30a trip breakers are the thermal elements. Should more attention be given to the instantaneous response of these breakers in order for them to respond the faults? As I said before SqD seems to have addressed this issue by reducing the mag calibration while offering a high mag which I believe was a former std calibration as optional. While C-H still used the original mag calibration as standard which equates to the SqD high mag and offers a low mag as optional which soimilsar to the SqD std breaker.
So the manufactures have already made inroads in the consideration of the mag pickups, but I think more serious consideration should be given. The mag elements are really very crude and cheep. If more attention would be given to the engineering and manufactue of a more precise mag element that may take a giant step to responding to faults. I know it would add to the cost but I think it would be incremental if it makee sense to do.
My personal belief is that every person I meet should hand me a crisp $100.00 bill. I also believe we both have the same chances for that to happen.
Ok to a reasonable level of risk. I have problem is when someone develops a product that may solve a problem ( I say MAY ) and the code makes it mandatory without fully vetting the product.
If the public is ever made aware of the fact that a very expensive solution to a problem that may not even exist was forced upon them by a certain organization what do you think would happen?
We need to keep in mind that the NFPA is a private entity, it is not a government run or paid for organization. No one can tell the NFPA how to do things, the only way to force them to do something is for areas to stop adopting the NEC as the code. But we don't see many areas do that, most areas adopt it and make amendments to it if they have issues with certain sections.
I am not so sure the NFPA should be a non-profit but that is really beyond my level of concern.
It is my understanding that the NFPA was created by insurance companies and manufacturers from the start so to say more than 100 years later it is a conflict of interest seems a bit late.
I have no idea how to make the NEC better but I am 100% sure that if it was being written and produced by a government agency that it would be much, much, much worse.
Lowered mag certainly makes better sense than afci. It would offer increased protection against faults, and another bonus is that it wouldn't contain any electronics that would be vulnerable to damage like the afci. Sometimes "new" isn't always good-Every year close proximity lightning strikes wipe out all those cordless phones attached to their bases, yet the veteran WE 500 (I think I still have one of those somewhere in my junk) still hums along.......
Its not even cheaper, an AFCI wont do squat. IF a person can make a splice correctly you dont need GCI.
Personally, and I might get flack, but in truth the real issue isn't even the NEC; its DIYs, handymen and lazy electricians behind nearly all electrocutions and most fires. DIYs are probably the worse.
For years I have given advice on DIY electrical forums and the stuff I see is beyond mortifying. Ive lost all faith. People do not join these forums to ask how to do something correctly, they join to reassure themselves in their ignorance. The other DIY posters are equally clueless giving away advice that is usually incorrect and often down right dangerous. More often then not they will argue with any electrician for who tries to give correct advice pages on end since they did it on their own home and it hasnt burned down yet. The DIY web articles arent helping either, they are full of disinformation.
Perfect example: DIYs will ask how to ground 3 prong outlets. Other DIYs will frequently tell them to drive a ground and connect to that. Im often left explaining they can not since a ground rod will not clear a fault. I get corrected by others who post a dozen links to internet articles that support the exact same thing. I tell them if anything install a GFCI try to convince them that will be easier since its to code. Nope, GFCI doesn't offer surge protection like a ground rod :roll: In the end those without any experience look right, I look like an idiot for pages on end while the OP drives a ground rod, HI's 3 prong tester lights up and the home gets sold as having an updated properly grounded electrical system :rant:
