electricguy61
Try using two "thin" locknuts, one against the connector, another as usual. That will shorten the distance the throat travels into the water heater.
The PVC from the drip pan is going through a hole in the encapsulation plastic, so it wouldn't be noticed until someone maybe noticed a wet drip-pan. So ? I can think of any number of things that could go wrong with a house that might not be noticed for awhile. Does code or common practice require a water-heater to be located in the heated living space or somewhere else a leak would be immediately noticed ?! I can imagine a lot worse places to have a major water leak than in a crawlspace.In this case I suspect that water coming from the drip pan drain would be noticed outside unless it was raining at the time.
As an engineer, I have a healthy respect for Murphy's Law. But still ... the water heater develops a leak, the homeowner doesn't inspect his crawlspace often enough to notice it when the leak develops, and the control circuitry on the leak detector fails, and ... you've got a wet crawlspace ! So again I ask, are you guys saying it's not appropriate to install a water-heater in a crawlspace ? I have never heard that before.There are methods for detecting presence of water if you want to detect leaks, but do you trust the control circuitry of detection system will still be functioning several years later when a leak finally develops?
That's weird. The special 240v/3500w configuration I got for this 10 gallon unit did not cost any extra. It's just s different heating element (apparently). Extra lead-time, of course.All of the 40 gal. electrics in my buildings are 277v., therefore that's what I buy, and I pay a dear price for them.
