From NEC perspective we still have a receptacle and cord cap, and hopefully approved flexible cord, and the issues that go with them such as cord deterioration over time, worn receptacle/cord cap components, missing/broken cord cap pins, etc. Now some of those things aren't as common to run into on the 50 amp receptacle/cap as they are with the 20 amp receptacle/cap and is likely the reason GFCI was required for quite some time now on 15/20 amp receptacles 120 volts not just for the RV but in a lot of places.I think what we are overlooking, in a way, is the requirement for the use of RV sockets and receptacles, which includes certain features to reduce shock when being handled. The 15 or 20 amp outlets in the pedestals are required to be gfci protected, but the higher amp outlets are feeders, in effect, not regular outlets. So, they will be split in the individual RV. Thus it is up to the RV owner to make sure their RV is properly protected inside, not the park owner. Many parks, at least online info is saying, are only allowing RVs of certain ages, which I think may be in part to make sure some of the newer safety features are in those RVs.
But, I am in Europe not the USA and have not used an RV since 1998..lol
Sure about that?
JAP>
It's reasonable to accept that the 30 and 50 amp receptacles are feeders. There is no way to anticipate the use of a receptacle, but when used to power an RV, these circuits are feeders. I've spent a lot of time at RV parks, and have seen a lot of weird...but haven't seen a range plugged directly into an RV pedestal.
So now we have to extend our definition of a branch circuit to a device that's plugged into a receptacle just because it has supplementary overcurrent protection built into it?
JAP>
but, JAP, are we required to have GFCI on a Range or on a Dryer? If So, When was it added and where are the breakers or outlets for it? In fact, especially in a trailer park, you would require outlets designed for it, as one would not be able to find the breaker panel in many instances that covers your specific outlet.
As far as the code is concerned, I would think the 50a Branch Circuit stopped at the Receptacle outlet.
JAP>
Not saying they can't have multiple CT's, but I think the most common method is a single CT. If all circuit conductors pass through it and there is no leakage to outside the intended circuit net CT output is zero, unbalance it and you start to get output, is all a matter of setting up how much to allow before tripping.. View attachment 21345
I though gfci's had 2 ct's.. in this illustration it would in theory read zero, then when current goes elsewhere it would read what ever current is faulting- not saying you couldn't design the line break this way- but don't they monitor each line? (off topic I know, well- sorry) now I want to break one open again...
Camp grounds I have been to.include the CBs required for that lot in the pedistal serving it. I've never measured, but within a few feet.
The breaker for that feeder is remote and could be 100, 200, or more.
The 50 amp receptacle is on a branch circuit in perspective to the RV park, or wherever the receptacle is located.
From the perspective of the RV itself, it is part of the feeder to the RV.
