Sierrasparky
- USA
- Electrician ,contractor
I believe this installation does not fall within that description. It simply is not a room divider.
It's not a divider? what is then
If it was made of glass then what?
We cannot be expected to place a recptacle where "someone may want to put
christmas lights on the rails " If it is just a bridge between two lofts would it be
practicle to place a table with a lamp on the bridge. In my experience I would
say no to a recptacle on the bridge.
So a game room with four sides established with iron railings and spiral staircase,with more iron guard rails, cut up into the center, does not require any receptacles? Where would I plug in my computer to get on Holt's Code Forum?
It makes absolutely no sense to require a receptacle if the railing was a 3' high wall and then say the code does not require it for a railing. I know in NC you would fail if you did not have one.
I am assuming it is a room not walkway or hall.
Attach wiremold and outlets to glass and see how happy homeowner is with that:happyyes:
Bridge between two lofts may be a little more analoguos to a hallway.
I agree with Charlie.
To me the rail does not create wall space but provides a safety barrier. The last loft I wired was an office space and there were ZERO receptacles along the railing (40' or so) and we passed rough and final inspections.
Because it passes inspection does not mean it is to code.
Because it passes inspection does not mean it is to code. I have seen a lot of hack work pass inspection.
:lol:Our senior Inspector is questioning my requiring a customer to install floor Receptacles along a 18' loft with an open picket railing over loooking the living space below. He does agree that if it were stick framed it would require a receptacles but since there is no wall there no receptacles are required. Help me straighten him out.
Kerosene lamps are nice :lol:What if they want to put a chair with a table and lamp there? We are required to install floor outlets on lofts around here.
If we have to place outlets wherever someone might want to put a table and lamp then I don't think we're gonna sell many more houses. How do you know they aren't Mary Poppins fans? They might want them installed on the ceiling!
Fanciful I know, but we don't install them everywhere someone might want them. As to installing by a loft railing the designer needs to look at the situation and decide if adding those outlets will help sell the house. That's probably in part driven by how large the loft area happens to be.
I agree but Charlie has always argued that there is no room on the other side so it is not a divider.
And I am sticking with that viewpoint.
IMO, the intent of the code is to require one.
IMO, it does not. If the owner wants to put an easy chair and a floor lamp by the railing, it would certainly be helpful to have a floor receptacle in the area.
And I am sticking with that viewpoint. IMO, it does not. If the owner wants to put an easy chair and a floor lamp by the railing, it would certainly be helpful to have a floor receptacle in the area. But that goes beyond code minimums, and into the realm of good design practice.
I do not understand this argument at all, the same thing could be said of any required receptacle in any location.
