James L
- Kansas Cty, Mo, USA
- Electrician
I don't even consider things like that when I'm wiring a run-of-the-mill house. For all I care, they can use a bathroom receptacle if they want to vacuum the bedroom.Even if every bedroom has its own 15a circuit, turning on the lights to vacuum is likely to trip a 15a breaker, but one 20a circuit can supply several bedrooms because you're only going to vacuum one room at a time.
As much as I can, I wire the same way I did back in the late '90s. I'm not going to change everything I do just because 1 in 500 houses needs a little bit more
