StreamlineGT
sorry, ceiling rafters....ultramegabob said:on the top of floor joists? wont it be in the way of the flooring?
dnem said:Code is minimum standard. . A true professional doesn't look to build to minimum. . At times there isn't a good reason to build above minimum [ex: why would anyone daisychain a short 120v/20a plug circuit in 10gauge]. . At other times exceeding the minimum is the mark of quality and professional installation.
Defining the code minimum can be hard. . Determining when to exceed it can sometimes be even harder.
brantmacga said:Nothing wrong with being a quality craftsmen, but when given the choice of a Mercedes and a Hyundai, a lot of folks want the Mercedes but can only afford the Hyundai. I give the customer the best they can afford, and sometimes that's just the minimum. Nothing wrong with that.
dnem said:A true professional doesn't look to build to minimum. .
iwire said:Or are you saying that the NEC minimums result in an unsafe installation?
dnem said:Building to minimum might be safe but safe isn't the same thing as professional.
iwire said:Regardless of the inspectors lack of carrying I would break out the MC in those situations. No matter what the inspector lets you do it is still a violation with your name on it until it is removed.
I see no reason to put my neck out to save the customer the cost difference between NM and MC. :smile:
wasasparky said:You've got to be kidding.
wasasparky said:So if safe isn't the same as professional
wasasparky said:Then unsafe isn't the same as unprofessional?
romeo said:My question is who is responsible,if a violation causes serious injury or even death, the electrician or the inspector? I think that both would be.
Do you run your raceways between terminations "as the crow flys" ? . Do you install diagonally to save a few feet of wire ? . NEC allows you to do that. . It meets code minimum to do that but its not professional.
peter d said:I should have squared everything off just so I could pat myself on the back. :roll:
dnem said:Do you run your raceways between terminations "as the crow flys" ? . Do you install diagonally to save a few feet of wire ? . NEC allows you to do that. . It meets code minimum to do that but its not professional.
stickboy1375 said:Now you can finally be a professional!!! :grin: :grin: :grin:
dnem said:If it was unsafe it wouldn't meet code minimum [theoretically]. . Building to minimum might be safe but safe isn't the same thing as professional.
peter d said:Too primitive...next time I'm going to run all my cable with a laser line.![]()
dnem said:Do you run raceways or cables diagonally [high to low, low to high] in stud walls ?
dnem said:Do you consider diagonal runs to be NEC compliant ?
dnem said:Do you consider diagonal runs to be safe ?
dnem said:Do you consider diagonal runs to be professional ?
Like I said before
At times there isn't a good reason to build above minimum [ex: why would anyone daisychain a short 120v/20a plug circuit in 10gauge]. . At other times exceeding the minimum is the mark of quality and professional installation. . Defining the code minimum can be hard. . Determining when to exceed it can sometimes be even harder.
Flex said:Im with you man. My name isnt on the codebook but it is on my work. They put all that time into that book to make what we do safe as possible and I respect that. Dont mean im gonna hide behind the code and say good enough.
