I don't know if I'm in the right forum for this question, but can people give me some tips and advice on running a larger job? It's approximately 4 months long and about 20 journeyman on site. It's a bid job so I want to meet or exceed their profit margin expectations and also make sure the communication and interaction with the other trades is what it needs to be in order to be successful on a job like this. As far as the scope of the work it's pretty straight forward and nothing too tricky. Running Utility underground and setting Switchgear and running Services and Panels throughout a new building for manufacturing. What trades take precedence over electrical and how do I keep this many men organized and staying productive? Any suggestions would be appreciated.
ask for the primavera file to see the schedule, and what it's like. you need to know
where they built unachievable goals into the plan. float days are critical. how many
do you have, and what are liquidated damages for impeding the critical path.
you can have things built into the schedule that make turning a profit impossible.
sometimes that isn't an accident.
straight multiplication puts your man hours at about 13,000, but that is 20 guys nonstop.
something like that will probably start with 4~6 journeymen, ramp up, and taper off.
how are you going to man it? ibew or craigs list? huge difference in strategy.
having staffing handled by a call to the hall makes it a ton easier than "interviewing".
unless the book is empty, and then your life will suck when the canasta club shows up,
and makes a chew toy out of your profit and loss statement.
the way stuff goes in this size range, you normally start with a few guys, add a foreman
when you get to about ten, add a second foreman when you get near 20, and you end
up with two full crews, and a few guys you manage yourself. if it's a fugly job, or a fast
track, you'd have three foremen under you, you'd be doing only a GF's job, and probably have
a good scheduler working the logistics so the material shows up and is staged where it needs to
be, when it needs to be there.
