jaggedben
- Northern California
- Solar and Energy Storage Installer
To add to what Wayne said...Thank you. Maybe that helped a little. If I had an inverter firing at 180 degrees out of phase with the resultant wave that a 208 load would see, I get no current, but also no power lost. With emphasis from ggunn of VA in = VA out, even though the 208 resultant wave has those period of time where they cancel each, the electrons aren't really in a battle, they just don't move.
When you have voltage and current waveforms that add to a positive number, and you flip the current waveform upside down as the inverter does, the result is a negative number which represents power flowing in the opposite direction.
(I prefer to think of the inverter as inverting the current instead of shifting it 180deg. The end result of those mathematical formulas is the same, but the inversion is a little better description of what the inverter actually does.)
To clarify, the current that the inverter pushes out is 180 deg out of phase with the current that the inverter would draw if it were a load. But it is in phase with the current drawn by a load connected in parallel to both inverter and grid.That's not correct. Your 208V inverter does push out current 180 degrees out of phase with what a 208 load would draw. So that if you connect a 208V resistive load in parallel with your inverter, and the load wants to draw the same current that your inverter is pushing out, those two currents add up to zero from the point of view of the main voltage source.
