If you are looking at this one:
https://files.sma.de/downloads/SBxx...3.1290147605.1708279129-2105309908.1708279129
Half the models standardize on the same output current, between grid configurations, while the other half has a current limit that is different for each grid configuration. Likely, they build it for a certain AC capacity for each pair of "neighboring" models, but don't use all of it at 240V for the model with less power. It probably has to do with the amount of hardware needed on the DC side to handle the power, and adapting the amount of it, based on what is needed. Like the same circuit board, but populated with fewer capacitors. The power in the part number is only valid for the 240V configurations, since it is either slightly less, or significantly less, for the 208V configuration of the same model. There are two models where it is exactly the same power, and a current limit that is a function of the grid voltage to compensate.
Older sunny boys (early 2010's), had integrated transformers, and user-selectable taps. So given an internal transformer as was standard, it was much easier to build the unit to maintain the same power, among the configuration options. They even had 3 options, 208V, 240V, and 277V, so you could triplex them on either kind of 3-phase grid.
