Mean while it creates a potent dangerous and expensive repair bill to home owners. My block of maybe 30 homes were built in 1964. As soon as we moved in back in 1975 and were away for a few days would always have a faint gas smell. By the time the gas company came out odor disappeared. Fast forward a few years and most of the steel current carrying pipes leaked and had gas company sleeve a plastic line inside of leaking pipe. A lot of the copper water lines leading out to the street had been rep!aced.Our Vo Tech shop teacher told us back in the 1960's that worst thing about a steel gas pipe carrying current when it runs close to a grounded source sparking can occur creating a hole in the pipe and causing an explosion. Not sure if local electrical provider in my area still will go out where the energised wire on an old 30 amp two wire 120 volt service would remove the remaining good wire ( neutral ) and connect that to the energised side and use the copper water service to.provide power. They told the customer that they had to get a new service within 30 days or else they would cut off old wire. Would not want to be the guy replacing a water meter without the bonding jumper during that.
