StarCat
Industrial Engineering Tech
- Moab, UT USA
- Imdustrial Engineering Technician - HVACR Electrical and Mechanical Systems
Jraef I could really use your input on this one.
Contact me at ********* if you have a chance.
I am dealing with a lockout matter on a Genesis Drive as made by KB Electronics, model KBDA-29 1P.
The usage is a 3 H,P 3 phase pump being driven on a CIP application.
I brought that unit on line in July and only recently did the drive start giving problems.
This pump does not get much use, only about every 2 weeks or so.
The fault is noted as LU-r [low voltage recovery] and is only supposed to happen under a low line voltage scenario.
The drive was returned to KB Electronics and they did tell me that they were also getting this fault on their bench test.
The only thing they did was to reload the program and send it back after their final test.
I get it back and same thing.
I set a Fluke 87 on the input terminals to the drive and recorded voltage on what would have been an all night run.
I ran the drive for 2 hours without trips before I left.
IN the morning I found the drived locked out on low voltage with the lowest recorded voltage on my meter being 205V on a 208V system.
All connections back to the main have been verified and I don't feel we are dealing with a power problem, although our power is known to be dirty.
I don't think we are dealing with SAGs below the trip point of the drive as the cause.
One of the Techs at KB said something about that model having some moisture sensitivity and that they developed a fix, but the other people at KB have been clueless about this when asked to relate it which is also a bit strange.
Any guidance is helpful.
I am currently going round with the MFG.
(I removed your email from the posting, spammers mine for that sort of thing and we don't want to give them cause to clog up our bandwidth thinking there might be more to find)
