Stranded wire in Industrial against code
Eddy Current
Is using stranded wire in Industrial work against code or just a standard? I know people use stranded and solid in Commercial work but almost never vice verse in Industrial its almost always stranded.
infinity
New Jersey
Journeyman Electrician
We always want to use stranded but it seems that lately engineers are specifying only solid. IMO #10 solid should not be permitted in a circular raceway.
steve66
Illinois
Engineer
I read you loud and clear. I'm adding a new paragraph to our standard specs:
"All raceways shall be rectangular." :)
tortuga
Code Historian
Oregon
Electrical Design
I go out of my way to use stranded whenever possible.
When I engineer a job I specify no solid conductors
My supply house stocks lots of stranded MC now since I usually specify it.
I like to use 10/2 MC stranded for water heaters.
Twoskinsoneman
West Virginia, USA NEC: 2020
Facility Senior Electrician
Pulling stranded is so much easier. I haven't done a ton of industrial but a couple years worth. I never worked with any solid in the industrial setting. Lots and lots of stranded and TC cable
Smart $
Esteemed Member
Ohio
The only solid I've used in industrial was 4/0 for grounding grid and from grid to above slab metal (skids, motors, and such). Solid can be bent to follow contours and hold its shape.
iwire
Massachusetts
I actually like solid.
For a short time the supply houses around here started stocking stranded MC, it did not go over well up here. It is now back to solid.
Trying to run stranded MC is like trying to push a car with a rope.
mikeames
Germantown MD
Teacher - Master Electrician - 2017 NEC
I have never seen solid wire that big. In fact can you even call it wire? Or do you just call it bar or round stock?
