I have to ask, are you just trying to be argumentative and difficult, or do you actually conduct your business in the way stated during this thread?
I do not run a business I work for a business and yes I have been truthful with my answers as far as how the business I work for operates.
It is one of the larger shops in MA and is very successful with a great deal of repeat business.
If we tried to hang a large transformer without engineering details it would most likely hold up the inspections. As I said in this area they are really cracking down on how things are hung.
30 years ago it was a free for all, we would do anything, now not so much.
I am very willing to believe your area is not like this .... yet.
			can easily see the p!$$ing contest with the Engineer that would reif you were the EC and Ingenieuer were the EE.  First off, he is in PA so seismic bracing is very likely not required there.
He jumped in and described how to hang it with rods, if that is beyond his qualifications he would not do that on paper.
			Second, my address is Florida, but I lived in the SF Bay area for 25 years, and I know a (2) simple 45 Degree mounted pieces of Strut would brace the transformer all day long if local code required seismic bracing.
And I believe you, but the point has been four simple rods regarless of size used to suspend a transformer on a trapezee are not going to provide any seismic bracing.
			Technically you are right that if asked, an Engineer should provide you with every detail under the sun.
But we are not talking about how I mount an outlet box, we are talking about how to suspend a transformer overhead. There is a large difference.
			If you want to build your jobs that way, then I suspect you won't be in business very long.
The company I work for has been in business since the late 80s.
			Good luck with that.  I will just build the darn rack and call it good.
And if you do that here, there is a good chance the inspector will ask for the calculations showing it is good.
Again, different areas have different procedures.
