lets ask another way. the induction motor is 10kW, the output shaft has a  perpendicular arm resting on it, a friction arm, the arm doesnt move or do  anything but get hot, is the motor doing any work to the friction arm??
Classical Mechanics answer: The shaft does no work on the arm since the arm does not move. But the arm does work on the shaft since the shaft is moving. The speed of the shaft does not change since there are additional forces (in the motor) doing work on the shaft to keep it turning. The frictional force at the interface converts relative motion against a force into heat.
fundamentally, if you increase universe entropy then some work was done. with a lossless cap coupled to a lossless inductor, energy can move back and forth w/o increasing universe entropy :thumbsup:
Classical Thermodynamics reply: You can increase entropy just by putting a hot mass in contact with a colder mass. No work is done in the process, but the total number of available states in the new system (side stepping for a moment into quantum physics) is greater than in the old system with the total energy remaining the same and the change is irreversible.
what about a satellite in orbit, it flies at constant Vmagnitude but the V and "a" vectors are continuously changing at a rate if 360 degrees per orbit. any work being done on the satellite
Classical Mechanics answer: Gravitational force does no work on the satellite because the force is always at right angles to the direction of motion (assuming a circular orbit.) For an elliptical orbit work is done by gravity over part of the orbit since a component of the gravitational force is parallel to the velocity. Potential energy due to the satellite's position in the gravitational field is converted to kinetic energy. In the other half of the orbit, going back toward apogee, negative work is done on the satellite decreasing its velocity and storing the energy as increased potential energy of its mass in the gravitational field.??
aint this physics stuff great!
For something really interesting, consider the Moon orbiting the Earth as the earth orbits the sun. Approximate the Moon's earth orbit as circular. Now the Earth's gravity is doing work on the Moon over part of its orbit because the gravitational force is lined up with the Earth's motion in orbit. End result is that the Moon loses kinetic energy as it moves to the far side of the Earth from the Sun and gains it back again as it moves closer to the Sun.
