Schlum,
First, welcome to the forum. It seems you are starting off on the wrong foot with this subject. I hope the responses you are getting won't scare you off. This is a VERY good site.
Now, I would like to offer some information that may shed some light on the responses you are getting.
It seems there is a problem with communications. I knew what you were talking about when you said 'meters in every room of the house', but others read the same post and got something different out of it. This happens frequently, it's no ones fault. As such, no one should get their feathers ruffled over it either, in my humble opinion.
To USA electricians, Canada does strange things. Like mounting panels sideways and having meters inside residences. To us (me anyway) the solution to meters endangering residences because they are inside would be to move them outside. Very simple fix, no new product needed, no re-engineering. They are weather tight for a reason. It would provide work for electricians and make the occupants safer.
This site centers around the NEC as used in the US. If you ask for solutions or opinions here the answers will be 99 percent based on that premise.
If you use statistics here to try to prove your point, be prepared to have your own statistics, plus others, used against you. If you say 'I know a such and such (like a meter tech)' that says 'blah blah blah', be prepared to get a response from a real 'such and such'.
This is the best site there is for electrical discussions. If you get mad and leave, it will be your loss. We would rather have you stay.
