Two circuits feeding one load
roger said:
Rick, look at post # 11, this is simply a one line diagram and the grounded conductor is not shown.
Roger
You mean this?
480sparky said:
Is this a more accurate drawing?
Now you have burned up the 120 volt load by supplying it with 240 volts.
Go back to the original illustration and think about it.
Roger
480sparky said:
There will be zero volts across the loads.
Draw it out with arrows for current flow, you will see a complete 40 amp circuit.
BTW, after the load we will definitely see zero volts. ;) :D
Roger
480sparky said:
It won't work that way anyway.... they're on the same phase, so there's no voltage.
Wha, for a minute, I thought my mind was goings nuts, (frig)?????
Roger
"What we have here is a failure to communicate."​
You quoted me before I could edit my response.
480sparky said:
Where is it stated the load is 120v?
Look at the illustration. :roll:
You've overloaded the neutral, then.
Wrong.
Once again, your taking a simple one line diagram and not thinking it through, both sides of the circuit would be identical, i.e., they would both have a grounded conductor. (not a neutral)
Roger
roger said:
Wrong.
Roger
And it would carry the sum of the amps coming from both breakers. This is not a MWBC.
Yes it would.
Think of taking a 40 amp single pole breaker and running two equal #12 conductors to a single 40 amp heating element, if you were to put an ammeter on the conductors one at a time they would be carrying 1/2 the load current which would be 20 amps.
Feeding two individual conductors with 20 amp breakers on the same leg or phase would achieve the same results.
Of course this is a violation of 240.8 in the real world.
Roger
roger said:
Yes it would.
Roger
of course this can't be a real situation because of field conditions and use. Having a disclaimer in the instructions to install on the same phase would'nt work unless the unit was rated for a maximum 240 volt
Why? In this exercise the unit is is 120 volt and would fry on a higher voltage.
Roger
roger said:
Yes it would.
Roger
But in order for current to flow, it would need the grounded conductor, so in effect you would have this:
Now your catching on!
I think we are getting somewhere now. :)
The problem is you're still trying to look at the load as being two.
Roger
roger said:
Yes it would.
Roger
By what you're saying here, this is what you have:
No current can flow because there is no circuit.
Roger
That is my point about not being field friendly. Guy comes in and finds only two spaces open (pole position 1 and 3).Turns it on and smoke.Or am i missing the whole thing. He should be using a 40 amp single pole but only has two single 20's on the truck.
Why did you get rid of the grounded conductor? You have just lost all that you had learned.
Roger
Rick, if the circuit is fed from the same leg or phase it will never be in jeopardy of a higher voltage.
Roger
