Sberry
- Brethren, MI
- farmer electrician
I thought about a load bank for burning up old fuel in the winter when the demand for heat was hi.
I have 2 of these. One like the picture, and one older one with the round door. The stoker part will burn anthracite coal, wood pellets, and dried corn. The burner have in one will burn oil or propane. The older round door one I have is only set up to burn solid fuel.I thought about a load bank for burning up old fuel in the winter when the demand for heat was hi.
My well guy told me I saved a pump by catching a check valve failure. My data was graphed at that time.I happened to look, losing tank pressure in the middle of the night, downhole check was leaking.
When you need to use a hole saw to say, drill a 1 3/8" conduit hole in a box where it already has a 7/8" hole in it. screw a 4S cover to the box. Use it to center the pilot and the hole saw won't walk on you. A common sense thing to me, but I have seen people struggle with this more than once.
This with a flasher button and a large wattage lamp lets you track down the circuit using a clamp-on amp meter.and this along with an incandescent bulb are very helpful in troubleshooting
Great for countersinking LB's!
Where were you with that hint 45 years ago?!!Great for countersinking LB's!
I've used clip on nuts for this in the pastIf the threads on a panel are stripped due to years of people taking the panel cover off and on, or over tightening the panel cover screws, I have a fix.
I put a thin wrap of Teflon tape (for plumbing) around the panel cover screw. Take my thumb nail and push the Teflon into the threads while spinning the screw with my other hand.
I then screw it in to the worn out hole on the panel with the cover off and coat around the screw and hole on the inside with JB weld.
Once it hardens, you can unscrew it, due to the Teflon tape not allowing the JB weld to adhere to the screw and the problem is fixed.
If you do one hole at a time, you can secure the cover with the other screws until it cures.
Time consuming, but if you have the time, it's a great trick
To my knowledge, I invented this trick, never seen anyone else do it
One thing I left out, best to scratch up the inside around the hole w sand paper to get a good bond
Clip-on nut - Wikipedia
en.wikipedia.org
You mean you used JB weld but Vaseline instead of Teflon tape? Can't imagine needing Vaseline for clip-on nut.
I fixed plastic trim on my microwave this way several years ago, except I used Vaseline on the threads.
Oops replied to the wrong post.You mean you used JB weld but Vaseline instead of Teflon tape? Can't imagine needing Vaseline for clip-on nut.
Lots of ways to skin a cat. Never tried Vaseline, but the Teflon works great. Some of the Teflon stayed in the new threads and made it easy and smooth to take the screw in and out.
21 Years old and just getting started in commercial work. All previous experience was helping dad on side jobs in residential.Where were you with that hint 45 years ago?!!
I just put up sone Sheetrock and did this. My wife doesn’t wear lipstick, so I got some at the Dollar store. The clerk there told me it wasn’t my color…… The lipstick will mark the paneling where you need to cut out the holes.
Better than what I did. I forgot to put the lipstick back. Don't think she bought my explanation!I just put up sone Sheetrock and did this. My wife doesn’t wear lipstick, so I got some at the Dollar store. The clerk there told me it wasn’t my color…
If you need to push a fish tape in to a live panel, get a rigid coupling of the pipe size. Put a bell pug in the end and screw it on the conduit threads inside the panel. When you push, the fish tape will stop at the bell plug. Take the coupling off and you have 2" of fish tape to pull in. Of course, none of us here would EVER open a panel that is hot, let alone pull wire in to one... but...
This was an idea I got from E C and M mag years ago. Credit where credit is due.
I once pulled live conductors into a dead panelI heard JWST (James Web Space telescope) discovered a galaxy where people often pull conductors into live panels. Crazy place that must be.
