So is it allowed on the kitchen small appliance branch circuit.
Man Dennis, this is a tough one to think about.
Why are you doing this to us??
The man likes puzzles. I totally understand. Stuff like this makes us think, read the NEC and do some general looking of things up.
It's all good.
I hope so, because that is where I am putting mine.![]()
You will also see the USB charging receptacles in vehicles soon.
Btw P&S are given free samples here http://www.legrand.us/passandseymour/usb-offer.aspx#.URRcyKWXJLY
You will also see the USB charging receptacles in vehicles soon. Some already have 120 volt receptacles in them for chargers. So now we go from 12VDC to 120 VAC and then back to 5VDC. Seems logical to remove the 120VAC from the process.
My 2011 chevy already had 2.
So I take it you are like me; your wife drives a better car than you do?Wife's 2012 Ford Edge has them also.
I love to watch people squirm....![]()
Unless it is something pre 1980 that may be debatableSo I take it you are like me; your wife drives a better car than you do?
As I see it ...
The pictured device is not a single receptacle. It is a TRIPLEX receptacle. A 15A 120V receptacle and two USB receptacle. All three are 'outlets.'
Code does not define 'outlets' in terms of voltage and current. Since there is more than one, you can have this on a 20-amp circuit. (FWIW, that 15A receptacle IS evaluated to 20A standards, because of this very code provision. ALL 15A receptacles are so evaluated by UL.)
Code specifies the circuits for kitchen counters and bathrooms, but does NOT specify what comes out of them at the receptacles. There's no reason you cannot have this on an SABC. Indeed, you could have the entire counter served by ONLY USB receptacles, and still comply with code. Code does not require there be ANY 120V receptacles; just that there be a 20A/120V circuit supplying them.
So, the code panels have a dilemma: do they jump harder off the 'design' cliff, or stand clear and let the market work? Might be best if they reconsider the design imvolvement they already have.
YepShouldn't this device be viewed as a combination of a receptacle and a hard-wired DC power supply? The two USB A connectors are on the output side of the power supply, so they are NOT connected to the AC feed terminals. That implies that they can not themselves be considered as either a receptacle or outlet from the AC feed's point of view.
/mike
