wirebender
 - North Central Texas
All right, a triple digit thread.
			thats the way i look at it too.before i got a truck with a cover on the bed i carried my wire in the back.before i used any of it in a house i inspected the roll for nicks and cut off the ends till i got dry paper.i know not a perfect way but you got to do it,wbalsam1 said:Water on the outside of the cable wouldn't have a deletirious effect, IMHO, just those conditions where the paper jacket surrounding the egc was wetted.....:smile:
What? :-?76nemo said:How often is the grounding electrode actually used? The more it is used, the more oxidization will occur.
"Hunt Stevenson: Afterwards we have a few beers and piss for distance."The OP isn't working for you, so let's not lose any sleep, or get into a peeing match.
LarryFine said:What? :-?
"Kazihiro: For us it's accuracy." ~ Gung Ho
76nemo said:.........You need oxygen to produce mildew........
wbalsam1 said:Pardon me, but I was taught that water has 1 part hydrogen and 2 parts oxygen......:grin:
76nemo said:Agree. This matter has too many angles. Just my opinion, and it's not worth much.
Please accept that. I am not an expert in anything except claiming I am a dummy. It was just my PO.
wirebender said:I think it might be the other way around?
The Iceman said:Is NM allowed in a wet location? The NEC says no. Sure you could, and probably do use it in wet locations that does't make it ok. I didn't bond a metal box to the grounding conductor when using PVC years ago and it never had any problems, does that make it ok?
sbrn33 said:this is kind of a desk jockey electrician against the working electrician deal. If you have wired more than a couple houses you have installed nm that has been wet. In the real world it happens and it doesn't hurt a thing. Water pipes are copper for krimenies sake.
