stickboy1375 said:You just got schooled! :grin:
PWNED!!!!!!!1
....as they say today :grin:
Fire Alarm said:I just learned that Rhode Island is the state with the longest name in the US. Pretty cool!
celtic said:PWNED!!!!!!!1
growler said:You just wait till the guys from Texas here about this!
Fire Alarm said:If rain is as caustic and corrosive as many of you claim, why don't humans melt when they venture out into it?
bradleyelectric said:didn't you see when dorthy through the bucket of water onto the wicked witch?
The Iceman said:I live at the beach in florida. If we get hit by a cat. 5 him or hurricane and my house floods with 8' of salt water then can we agree to replace the romex?![]()
wiredit said:I'm sure if it were a problem, the manufacturers would put a warning label saying to have lathers immediately cover walls behind romex installation to avoid moisture on romex.
peter d said:Romex cannot be installed in wet locations (such as an underground or outdoor conduit.) They don't have to put a warning on it - it's already in the NEC. Getting soaked with rain sure sounds like a wet location to me.
buckofdurham said:Water is not going to hurt any thing on runs of wire. It will however effect the connections and cause them to corrode. Check all the connections at light fixtures and outlets, re-do them. How many electricians do you know that use pickups with rolls of wire stored in the back in the pouring down rain.
Sometimes the copper will tarnish. Again it is the connection points that are the most important. If the wire is not shinny copper sand it a little before you put the wire nut on. That will be fine, I've done it hundreds of times.
Circuit breakers now that is a different story if they get wet. They will rust and cause them either not to work at all or not properly. Deffinitely replace any wet breakers. I done a job one time some one had left the hub cover off an outside panel. The breakers would not trip at all. (FIRE HAZZARD) I busted a couple open. The insides we're just big globs of rust.
satcom said:"How many electricians do you know that use pickups with rolls of wire stored in the back in the pouring down rain."
I think you should correct that , from electricians, to trunk slammers, and Mr side job, have rolls of wire stored in the back in the pouring down rain."
