LarryFine
- Henrico County, VA
- Electrical Contractor
Actually, I just wanted the barcode stickers to point toward the wall.
Then stop buying at "Big Box"Actually, I just wanted the barcode stickers to point toward the wall.![]()
Vinyl siding, yuck. Best thing for buildings with vinyl siding is to call the fire dept. for a practice burn.BTW, vinyl siding, not stucco. Single family dwelling, not apartment.
Don't tell that to people buying the houses. But then again there are three types of houses that people buy. Starter homes, investment homes, and the ones people hope to have when they retire.Vinyl siding, yuck. Best thing for buildings with vinyl siding is to call the fire dept. for a practice burn.
I don't know what is worse, vinyl, or hardboard, AKA "Masonite", there is product that is worse called Cladwood, think particle board between paper but don't think it is even on the market anymore.Don't tell that to people buying the , . But then again there are three types of houses that people buy. Starter homes, investment homes, and the ones people hope to have when they retire.
I'm not following this statement. Half the houses in this area have vinyl siding, many worth well north of $1M. Can you elaborate or explain?Vinyl siding, yuck. Best thing for buildings with vinyl siding is to call the fire dept. for a practice burn.
I'll agree that Masonite siding is awful. Not familiar with Cladwood.I don't know what is worse, vinyl, or hardboard, AKA "Masonite", there is product that is worse called Cladwood, think particle board between paper but don't think it is even on the market anymore.
Yep, it was on the house I grew up in. The FHA pushed that stuff for financed remodels. When I got the house, I tore it off.Who else ever had 'insulbrick' on a house? Was all the rage 80 years ago, asphalt siding with asbestos embossed to look like brick and installed as siding. Future slums.
Hardie Board, if that's what you meant. It's not the same as Masonite at all. It's a concrete type siding. Masonite is just a wood composite similar to press wood. A "mushy paneling", if you will.I don't know what is worse, vinyl, or hardboard, AKA "Masonite", there is product that is worse called Cladwood, think particle board between paper but don't think it is even on the market anymore.
Looks like Tri-plex or MH feeder (without the ground). I think it's dual rated like USE-2. They are usually individually marked.Just being a nit-picker. Are those conductors from SE Cable with the sheath removed (not that I wouldn't do it)? Are they marked?
Mark
Yes, they are from SER. The insulated neutral looks so much better than twisted bare from SE.Just being a nit-picker. Are those conductors from SE Cable with the sheath removed (not that I wouldn't do it)? Are they marked?
I have done this many times; it has never been questioned before.Looks like Tri-plex or MH feeder (without the ground). I think it's dual rated like USE-2. They are usually individually marked.
Larry would have to tell us for sure.
Most reasonable inspectors wont...I have done this many times; it has never been questioned before.
Nothing else to do for some of us.I have done this many times; it has never been questioned before.
(I mean by an inspector, not you guys. Y'all question everything.)
I've got them. How much?? Just kidding, Larry can have my supply at cost. And, as I said, I have NO issue with the conductors, I just wondered if some Inspectors might.I will wait and see if Larry can find dp 30 CH breakers. Maybe he doesn't need them but from what I heard they are virtually unavailable
They'll be BR, and there are plenty here, but, I won't need any. I will be re-feeding the laundry sub-panel with a BR260, which are also in stock, and I'll need one BR115 and three BR120s.I will wait and see if Larry can find dp 30 CH breakers. Maybe he doesn't need them but from what I heard they are virtually unavailable
Masonite, & hardboard are the same type of product, just like a Twistlock®, & a locking plug, the brand name & the product type. Replaced some failing hardboard with Hardie board, & Hardi plank, on my rental made a run down looking building a decent looking place.Hardie Board, if that's what you meant. It's not the same as Masonite at all. It's a concrete type siding. Masonite is just a wood composite similar to press wood. A "mushy paneling", if you will.
