mbrooke
Batteries Included
- United States
- Technician
But honestly who is actually running circuits in that way with NM?
If they take advantage of that section it will likely be to use two 2 wires in place of a 3 or 4 wire and the two 2 wire cables would be run with each other not adding to EMF.
As Karl had always pointed out if you wire normally, following the NEC it will be the appliances that will be the largest source of EMF in a home.
If you wire to code. But how do we know a neutral isn't touching a ground?
