mbrooke
Batteries Included
- United States
- Technician
I did hear of an incident in a school building one time where they ran three banks of lights in all the classrooms, Line A supplied the front of the room, B the middle and C the back (or something similar to that). Problem was before /after hours maintenance would come in and turn on the front row in all rooms and nothing else. These lights maybe even remained on during the day when a room wasn't in use. This put all of that load on line A and limited loads on other two lines. Over time this apparently did cause neutral issues, but was not a situation ever planned for. The plan was load balancing when all the lights were in use
Now I can't believe that lighting was that significant of a load to cause this problem when there was probably more HVAC load then lighting, and that HVAC load was more likely to be more balanced, but this is a story I was told and not something I personally witnessed.
Schools back in the day had very limited HVAC because school would be out for the summer, and oil fired boilers used in the winter. There used to be some elementary schools that were fed by nothing more than a 50kva pole pig.
