Alwayslearningelec
- NJ
- Estimator
To do a take off(most times) is not all that hard, depending.
The problem I have sometimes depending on the scope is understanding how the electrical installation will be “built”.
For 80-90% of installs I understand HOW it’ll be done.
I have the following circumstance and would like input on only how the wire will be pulled. Setup, locations of wire reels etc. Conduit installed by others.
I have 24 sets of 4” PVC with 4 #600 XHHW copper.
If someone could provide a brief step/step on how this pull would be done, generally speaking that would be helpful.
I know the labor units would cover 99% of labor required to pull but I still would like to understand how it’s done.
Thank you very much.
- The run is from a generator in a generator room on grade to EM switchgear room on grade. This is new construction.
- The run is about 550’ outside and turns right up into the gear and generator.
- There are about 5 – 90’ with a pull box in the middle of the run.
- How many runs would be pulled at a time? Assume the reels would be paralleled and you’d pull one set at a time.
- How many men. Assume 3.
- Where would reel be setup. Would there be multiple setup and breakdown.
- What equipment would be used to feed and pull. Tugger?? Would have to make up a pulling head obviously??
