mivey
Yes. I think it is a different alloy.wptski said:Isn't true that the AL wire used today is made differently and less likely to corrode compared to what was made 25 years ago?
SmithBuilt said:I have seen cases where I believe Nolox would have prevented connection problems. It certainly prevents the white chalking. I now use it on all the al connections.
On another note it is very good on battery terminals. Clean them good and coat all the exposed lead.
quogueelectric said:No alox is an oxide inhibitor. Aluminum is a good conductor aluminum oxide is not the No alox is supposed to prevent oxygen from contacting the aluminum that is why you are supposed to put it on before it is brushed because it keeps oxygen from combining with the alluminum to form a poor conductor. I have seen idiot after idiot putting the product on after the connection had been made and this is why aluminum had so many fires is because of untrained monkeys installing it.
You will notice AL devices have a rough grid pattern etched into the plate behind the screw. This helps hold the wire tight as it expands and contracts.POWER_PIG said:...I am wondering about the mechanics behind the aluminiun rating/vs. the cu.
What specifically do you have issue with there iwire as most of that is how it seems to be?iwire said:You really should do some more research there Mr cow.
Some instructions call for the compound to be applied before brushing as the aluminum oxide forms almost instantaneously. The oxide is not a good conductor and the only reason there are not more problems with aluminum terminations is the fact that the oxide is very brittle and shatters when the conductor is terminated.mivey said:Brushing? I would brush a wire before putting on de-ox as I'm faster than the majority of the oxidation that would occur afterwards.
Some of the compounds are not listed for use with copper...only for use with aluminum. Others are listed for only copper and still others are listed for both copper and aluminmum.JacksonburgFarmer said:Depends on the enviroment. We do mostly agricultural work, outside, in hog barns ect. I use it on every lug in the panel, even if cropper conductors.
mivey said:What specifically do you have issue with there iwire as most of that is how it seems to be?
The only wires we did not de-ox first were those under wirenuts. We would twist the conductors, de-ox 'em, then put on the wire nut. For terminals, we would de-ox first.
Depends on the enviroment. We do mostly agricultural work, outside, in hog barns ect. I use it on every lug in the panel, even if cropper conductors. Try taking a lug loose that didnt have deox, and has been there for 20 yrs....GOOD LUCK!!!! You will be changing the lug/breaker/bussbar whatever. You should use deox all the time, makes a better installation. What does it cost, 5 bucks a bottle, bottle lasts how long?????
iwire said:I do not believe the problems with the original alloy AL conductor have anything to do with untrained monkeys.
I don't 'de-ox' anymore unless the listing requires it.
Same here.
brian john said:1. The right product for the right job.
2. There are a variety of NO OX type compounds, for a variety of installations.
3. DEOX does not necessarly make for a better installation.
I believe this is a better choice for some of the applications you noted. This product has a thicker viscosity, easier to apply, LESS RUNNY, not as clumpy/chunky.
http://www.sanchem.com/aSpecialE.html
