Jim W in Tampa
- Tampa Florida
I have accidently shorted out 277 and it can easily burn #12 open from an arc. I really will only work it live if conditions are safe and is needed. The call is mine alone.
I'll vouch for the POCO (PG&E) issue - you would never get another oveer-head service change done again - for any amount of money - if we had to wait for PG&E to show up.... It could take weeks and mile of red-tape - reconnect could take years! Under-ground they pay a little more attention to.... I have tried the process to get them to come cut over-head - and basically had a dispatcher tell me - 'do what you gatta do....' Paper work is 6-8 weeks, just to get a Rep out to tell you have 6-8 weeks for a crew to get the paper work to schedule 6-8 weeks out. So yes - if the drop does not need to move - I cut & reconnect it too.I do service changes, 120/240v hot. I cut the drop and then reconnect it at the end of the day, but thats because my POCO is.... worthless.
Other than service changes.. I see no reason to work hot. It just isnt necessary in a resi situation.
~Matt
Y'know, if we had more electricians like you, we'd have fewer electricians like you.
That's by far one of the dumbest things I have ever read on this forum.
You mean to tell me that "You" can't twist (2) #12's together when hot? Only when dead?
will working on live 208v/200a kill me less than 208v with more than 200a available?
Why cause you have been brain washed into a false pretense of how electrical work is done? Things are worked hot everyday with no problems. Its guys like you that condescend on the guys who work things hot.
So, do all the EC's out there own bucket trucks ??????I was told by a PG&E lineman: "Dont call us for disconnects and reconnects for overhead services, youre an electrician, you can cut and reconnect the line safely. Dont call us until youre reconnected and finaled, then just call for a meter seal."
~Matt
I was shocked [pun intended] Since then, I havent called them for an OH service change. The guy made it clear it was not needed for him to come out and reconnect the service. I have a friend that needed a service change a few days before thanksgiving - his meter socket was ready to go into meltdown. I called for a reconnect, and they told me 1 week. I asked"so my customer will not have power for the next week?" i was basically told to 'do what I have to do' and they will be there in a week.
Larry, I sure hope your POCO is more cooperative, because if you are leaving your customers without power for weeks, or even days, your customers will be quite limited.
I, as an electrician, do what needs to be done safely, within my own limits. I have the proper equipment to cut and reconnect an OH drop safely - so I do it when needed. Heck, I use more PPE than our POCO linemen. They dont even use voltage rated gloves, they just use leather gloves.
Condensed version: My POCO sucks, I cut and connect resi services when needed, I use PPE.
~Matt
If you mean me, no, I don't leave them powerless. Here, the POCO is responsible for providing and installing everything on the line side of the meter, from the POA to the meter line terminals.Larry, I sure hope your POCO is more cooperative, because if you are leaving your customers without power for weeks, or even days, your customers will be quite limited.
Nope, load has nothing to do with it. Shock hazards are based on the voltage drop across the body. Arc flash is based on the duration of the arc and the amount of available fault current.
~Matt
Now you know you are talking about two different scenarios. Keep it sensible or you will never help your argument.
According to the BLS, in the US, in the workplace alone, 2,000 arc flash victim are sent to burn units and 1,200 electrical worked are killed from electrical contact accidents each year.
So while some have no problems, about 3 are electrcuted and 4-5 end up in burn units each day. With your attitude you are a statistic waiting to happen.
Blah, blah, blah. If you were to have read the thread you would know I wasn't talking about the safety aspect like everyone seems to like to throw out there when its not the topic. It was an arguement that a guy can just as easy twist some wires together live or dead. You're not gonna twist them any different because they are hot.
You could literally talk to you're blue in the face - unless you 'lie' and say there is a lost neutral - you won't get anyone near it for quite a while. And I have done just that - the result was the POCO lineman "Oh I see the problem...." Then instead of connecting it, turned away and left, while it would have taken two minutes to connect - already in the bucket and up there... Then you're forced to "temp it up" until the POCO can come do their "permanent connection". (crimped barrel spice) Some EC's just will just use a blue wire nut - I KID YOU NOT! I have seen temp'ed up OH drops stay that way for years! So I at least do it in a method that will last and can carry the full load... The same crimp the POCO uses...(page 11) Or these. I used to split-bolt 'em but find it too much effort, and exposure. The only reason they get ticked if you do UG ones is you might accidentally cut someone else off... Or expose their conductors to rain water... For that - you can plan to wait for at least a month or two.I would be on the phone with someone. I may be able to make the reconnect but I know for sure I am not properly equipped. Those are the POCO responsibility and it would not take long to have that attitude changed. Let the customer go without power for any unnecessary length of time and we'll see how long it lasts.
One tool I recently came up for working in houses with poorly marked panels is a simple one. I took a two wire lamp cord and hooked it up to a toggle switch. I call it the "Tripper" and I think you can guess what it's for
