- Wisconsin
- PE (Retired) - Power Systems
You are correct it is the work done by Faraday, not Fleming, that links voltage (emf) and flux.They mention flux, current and motion. Not voltage.
But if a current is flowing through a conductor, according to Mivey, we should be able to say one end of the conductor has higher potential than the other end.
Congratulations on contributing to the effective use of electricy. (This is not meant to be sarcastic, I do mean thank you)Do you honestly think I couldn't design such things without understanding phase relationships? And that they would actually work?
That they do and are in service in many locations in different countries attest to the fact that they do work, and do so reliably.
Designed and supplied any such systems yourself?
And no I have not designed a rectifier circuit. For the past +30yrs I have dealt with the interconnection and application of transformers.
Seriously, lets stop talking about 3-phase systems and rectifier circuits.
Lets get back to a center tapped transformer winding on a single core. This is the probably the most common source found in the US.
