That is an old photo that isn't compliant anymore - they need to be tamper resistant![]()
Old picture in a new thread, they need to be TR![]()
They were installed prior to the TR requirement.
Actually since the percentage of dwelling unit fires that are said to be of electrical origin is less than 15% of the total number of electrical fires, we would be much better off from a life safety perspective to put the money that is required for AFCIs towards the cost of a fire sprinkler system.
Our local code permits you to delete the AFCIs if you install a code compliant sprinkler system.
Most will agree the sprinkler system is a fire protection method, even though fire protection is the idea behind AFCI, they have not convinced everyone they are that effective.Hmpf. Not much of an incentive when you compare the cost of a panel full of AFCI's to the cost of a whole house sprinkler system. Not that I think sprinklers are a bad idea, but someone needs to find a better carrot.
...and those that brought AFCI requirements into the NEC![]()
Now I probbly derailed the thread:angel:
:thumbsup:
I would gladly and willingly pay for a residential sprinkler system in lieu of AFCI's.
Talking of Morons your beginning to sound like one. I speak from experience with over 35 years working in the trade. I 'm more then qualified to speak here for the industry to mske a change on out dated method for wiring the number of outlets on a branch circuit. Why do you think almost every other nation in the world has adopted such a standard for the numer of outlets. They are way ahead of us!!!There combined experience and education far out ways you lack of understanding.
lol
15/1 A GFI
#10 AWG
1 receptacle
size for 1% V drop
get ground bed below 2 ohm
use NGR to limit fault with appropriate protective relaying and UV cb's
Same here. I bet most HO insurance gives you a discount for having sprinklers before they give you one for having AFCI's as well.
Who ever came up with the 10 outlet theory got bamboozelled into thinking the some crack pot engineer got it Wright? Wrong
Number of years in the trade doesn't impress me much, I've met plenty of people with decades in the trade who lacked a basic understanding of the most simple concepts.
As for what the rest of the world does, that doesn't impress me much either. There are a multitude of standards around the world with many differences between them, some of the differences are quite profound. We here in the US and Canada have a system that works fine despite its flaws. You're seeking to fix that which is not broken.
Despite it's flaws is exactly the point. That is why the manufacturer came out with what they call arc fault circuit interrupter to protect this type of wiring scheme. What they didn' tell everyone is how they function. They work similar to older GFCI technology . They are actually available fault current interrupters design to open when there is not enough short circuit current available with you as many as you want number of outlet scheme that you think is fine
So Mr Expert, can you please explain to me how a properly wired circuit starts a fire due to 'too many outlets'?
I really don't believe you can so your idea or NEC proposal will go nowhere.
No, they came out with the AFCI to line their pockets, there was nothing altruistic about it whatsoever.
I will also add that a dwelling unit sprinkler system is much less expensive than a commercial system. (Still more than AFCIs but at least sprinklers actually do something)
No threading or hard pipe to run.
Ok, see ya (I think you meant signing off) and we will look forward to seeing your proposal in the 2017 PI's.I'm done with this post sparking singing off
That is not how they work. They work by some fancy (proprietary) algorithm that looks at an arc signature. To minimize false trips they do no look for an arc signature of a parallel arcing fault unless the current exceeds 75 amps. They are designed to detect arcing faults which they claim are responsible for the majority of dwelling unit fires.Despite it's flaws is exactly the point. That is why the manufacturer came out with what they call arc fault circuit interrupter to protect this type of wiring scheme. What they didn' tell everyone is how they function. They work similar to older GFCI technology . They are actually available fault current interrupters design to open when there is not enough short circuit current available with you as many as you want number of outlet scheme that you think is fine
