sparks1
- Massachusetts
How many electrical fires/year are acceptable to you? If that number isnt zero, then you are accepting a compromise of systems. If zero was your answer, sure, it's possible to build a bulletproof (fireproof) electrical system, but at what cost? Even RMC piping, metal boxes, fire annunciation, compartmentalization, and suppression can still catch fire if the right chain of events occurs. You could build the building out of concrete, metal stud, and durarock; the building would be basically fireproof, but then you go and put mattresses, couchs, carpets, drapes, etc. i.e. things that are very flammable and produce toxic smoke in it, and all bets are off.
NFPA results already show that small things, like interconnected smoke detectors, raise survivability of a fire substantially. Personally, I think having sprinklers in houses would do more for all fires than anything an electrician could do even with a blank check. Not all fires are electrical in nature, and many electrical fires are extinguished by de-energizing the equipment, something we simply dont have available on a residential scale (e.g., something that would automatically throw the disconnect from the xfmr upon a fire alarm).
Still we need to have a standard since there is none . One electrician thinks it should be 10 outlets another thinks it should12 , another thinks we he should wire all four bedrooms and the list go on and on. It our liability. It our skin to protect as well as the lives of the occupants.Go tell it to the judge when your dragged into court in of law and tell we have no standard for the number of outlet allowed on a branch circuit. And that you thought it was 10???It's voo doo wiring without one. New Mexico is working to legislate one . All of this should be look at to consider the distance limit of the branch circuit, the number of outlet set s limit based on distance and some say the voltage drop can Handel 10%
I know the guideline are 3% and 5% respectively maybe this could set at 10% we meet to set real limits and come up definitive standard
