Not sure what you are saying here.  EVs differ in whether they have their regen on the brake pedal, the accelerator, or both.  Some have it all on the accelerator, and the brake pedal is just for friction brakes; when you are off all pedals you get maximum regen.
Others have it (almost) all on the brake pedal, with the first portion of the brake pedal travel being regen only.   Further brake pedal travel starts blending in the friction brakes.  For those, when you are off all pedals you are (almost) coasting.
Cheers, Wayne
when you take foot off of ev pedal the car does not de-accelerate, you cannot get regen energy unless you are taking it from kinetic energy, so no, there is no regen when taking foot off of ev go pedal unless you are expecting the car to slow down faster than wind friction dictates. if they are regen brakes then they are not friction based. a mix of regen and friction is wasting energy.
and there's been a few posts since yours.... so i try and answer.
cost of getting fuel to gas stations is baked into the gasoline/gal price. extra emissions for doing that, yes, but again, the totals per kwh still favor oil.
and no, people wont go to EV because oil prices are high, the shear # of available gallons of oil just means the owners of the oil can simply drop their prices to beat any reduction in EV vehicles. oil is plentiful and easy to harvest and refine. EV's are not.
and making newer battery packs? hah, Lithium is the best they have now, a dangerous material in many regards. its a dangerous chemical and it is dangerous in density (aka bat packs).
			Simple, its emerging technology. It still has high costs.
That is a lot of rambling but if there is money to be made electric cars  will be here and will be supplied with power to be charged.
it is emerging, in a market that already has cheap fuel source. so now they have to compete for whats already out there. and btw, gasoline/diesel engines are also still emerging, newer and better everyday. so if EV is to be a viable alternative, it has to accelerate in development just to catch up, AND, has to be priced at about the same as the existing, otherwise you have little customers.
there is $$ to be made in EV, in a very small % of the market, which usually attracts few investors.
emissions aside, until the EV's are similarly priced against their dino counterparts, nobody is buying EV's at the rate they are buying dino cars.
also remember, solar is a fixed day-time only energy source (impacted dramatically by weather), at any given time you have X # of kwh available. oil on the other hand is a reservoir and the siphon can be dynamically changed according to demand. and let alone the issue of power delivery system that will take billions to upgrade, and billions to add new to support proliferation of EV's need for power. and the risk..... oooops, part of the grid went offline, ok, so the north east sector of the US cant drive today.
its extremely hard to move away from oil based fuels.
