jaylectricity
- Massachusetts
- licensed journeyman electrician
Since the 2020 NEC went into effect I've been installing meter/main sockets with 4-wire feeders going to the panel. Part of the changes required is the GEC from the water meter now needs to go outside. Sometimes this is relatively simple, other times the water meter is on the other side of a finished basement.
Is there a cheaper way to have a switch outside without it being the first overcurrent device? I'm looking for meter sockets with a switch built in rather than a meter socket and a separate safety switch.
