And we don't have 110, even though many people are calling it that. We do have 120.And we do have 110V for
Electricians are appalled at that now, but I was recently in one of those early '90s homes to troubleshoot an exterior receptacle on the back of the house.I remember the days of installing one GFCI circuit per house, it was code compliant.
Right. We had 110v back when the high-leg was 190v.And we don't have 110, even though many people are calling it that. We do have 120.
I was referring to residential installations. I think the FECC refers to commercial buildings.It says your an instructor in Florida, if I am not mistaken for the last decade (since 2014) its been in the FECC section C405.7.3 states that feeders are to be sized for a maximum voltage drop of 2%, Branch circuits are under FECC C405.7.3.2 are 3% so I would say its not accurate to say the Florida code omits voltage drop, its just not in the scope of the National Electrical Code to even address the topic so it went in a different code.
Not really a big issue.And we don't have 110, even though many people are calling it that. We do have 120.
⁹It says your an instructor in Florida, if I am not mistaken for the last decade (since 2014) its been in the FECC section C405.7.3 states that feeders are to be sized for a maximum voltage drop of 2%, Branch circuits are under FECC C405.7.3.2 are 3% so I would say its not accurate to say the Florida code omits voltage drop, its just not in the scope of the National Electrical Code to even address the topic so it went in a different code.
You have never been in my neighborhood in 90+ / 98 % weather here in Western IL..........And we don't have 110, even though many people are calling it that. We do have 120.
Sounds like a split bus panel. I wouldn't even attempt to add to it. Adding such large loads will cause issues on the old bus and to have in most cases catastrophic failures. Recommend to customer replacing with new panel.Got 4 breakers at top of panel, 1 each for hw, ac, dryer and heat plus 2 60a, one for each half of the rest of the panel all wired directly to the meter.
15 amps is 1800 watts. Holy smokes. You want 6 arena lights in each bedroom?15a per room for lights and 1 20a per room for outlets
Yes, overkill.15 amps is 1800 watts. Holy smokes. You want 6 arena lights in each bedroom?
A separate lighting circuit in each room in a residence is foolish, but each bedroom on their own circuit is not a bad thing.15 amps is 1800 watts. Holy smokes. You want 6 arena lights in each bedroom?
I've done that in some retirement communities, with each room having a 20 amp circuit for receptacles. Then a lighting circuit or two throughout.A separate lighting circuit in each room in a residence is foolish, but each bedroom on their own circuit is not a bad thing.
That's a real minimum, not something I would EVER wire to. I am not in the cheapest way is my way. I hardly ever wire 15 amp receptacle circuits. 20 amp AFCI/GFCI breakers cost the same, and I feel better having more receptacles. Not that silly 12 foot rule (so a lamp with a 6 foot cord can fit most anywhere, but then there is if it sits on a table, then you have to account for drop to floor length....His question was ...........how many receptacles can he put on a 15 amp circuit.
Multiple the square footage of the dwelling times 3 VA per square foot.
Divide that by 120 volts.
Then divide that by 15 amp circuit breakers that you will need.
Round up if you have a remainder (fraction thereof).
Some people think all licensed guys do everything correct, while all unlicensed guys do everything incorrectAnd why the licensed electrician remarks? Trying to insinuate all licensed electricians are the same?![]()
Or anyone over 60 years old, or grew up with people who were around before 1960. It is a learned thing, like accents or misused words (I'll axe you a question grates on me!).We do not have 110V either, mostly just DIYers & foreigners calling it that![]()
Is was not a code violation then. The bath lighting could not be on the circuit, though.Isn't that a code violation?
How'd that pass?
