Yeah better than the expensive way in Court with a toasted house.Good chance to educate him on the Polaris connectors.. or let him keep using big blues so you can get more repair work. :grin:
Where's the disco?
Why not put the disco over the cable through the wall, as we usually do?Just to right of the J-Box out of frame.
That's the main disadvantage of Bob's in-line splices, which I have used. I'd like to see a "U-turn" version, sort of like a 2-hole mechanical lug without the stud tab.
Hey, I wonder if one could cut the tab off of a 2-hole lug and use it as a splice? Legally, I mean.
You strong like bull, you can make the wire 'U-turn'.![]()
Mongo like!Maybe or you could use this one.
http://www.idealindustries.com/products/wire_termination/lugs/lugs_split_bolts_street_light.jsp
How do you identify a AL/CU wire nut by looking at it?
You sure you have 4AWG and 6AWG - I was expecting larger j box just to be able to bend the #4, and getting them to fit in a blue wire connector may not be impossobile but is not going to be easy. I see they did a fine job of bonding to the box also:roll:Yes. Not any Before, but here is the AFTER Pics when the HVAC contractor that installed it 4 years came to repair it. Needless to say he is going to hear from me.
Hey Bob I like that one. Will it fit in a 4 inch J-Box?
Chalmuit to be honest I was guessing at the size. So I went and measured it.What about wire fill? If all the conductors were #6, you would need 25 in?. The box shown is only 31.8 in?. So, 3 #2's (L-L-G) and 2 #6's (L-L) would be more in? than 31.8 in?.
Well that is what Bob and I discussed briefly, we do not know that a AL/CU wirenut exist. That is what sent the red flag up when I seen how the contractor fixed it. I was not sure so that is why I started this thread.I have used the purple wirenut before. .
They're purple.How do you identify a AL/CU wire nut by looking at it?
John you are correct, I thought the Ideal 65s were only listed for AL to AL or CU to CU.
http://www.idealindustries.com/products/wire_termination/twist-on/twister_al-cu.jsp
They're afraid we'll use them.Anyone know why they don't make the purples in Larger sizes?
Once you have conductors larger than #6 you will need boxes sized by raceway sizes instead of conductor volumes. See 314.28(A).What about wire fill? If all the conductors were #6, you would need 25 in?. The box shown is only 31.8 in?. So, 3 #2's (L-L-G) and 2 #6's (L-L) would be more in? than 31.8 in?.
