letgomywago
 - Washington state and Oregon coast
 - residential electrician
That's assuming someone didn't return a self test dualfunction when the self test indicated and issue. Best way to test would be the new gfci breaker and then a new afci after showing that the gfci is not detecting a ground fault. When afci trips its never instantaneous its after a second or 2 then they trip.Replace it with a regular breaker. If it holds, you have a lose connection or possibly a flying splice.
An AFCI found a flying splice that I would have never found if I hadn't upgraded the breakers to AFCI's.
