hbiss
EC, New York NEC: 2017
- Little Falls, New York NEC: 2017
- EC
Yeah, she's kinda cute. That's about it.
-Hal
-Hal
Its in the hundreds.
Forum can not be sued from my understanding.
I think at this point you are the best considering you know more then most Philippine electricians :happyyes::happyyes::happyyes:
Tersh, here is an example of American DIY:https://www.youtube.com/watch?v=X9ro7Tc2nFI
Great vid btw.
Most of Philippines electricians didn't even finish high school. They are mostly from the poorest section of society. They don't have special electrical training before becoming electricians.
Right now, there's more of a market for a failed apprentice pursuing work ...
~RJ~
... I _DO_ know what not to do. I worry about those who _KNOW_ they have all of the answers but who don't really. I make mistakes and try to learn from them; too many don't make mistakes (or admit to them).
Think in some instances you will find that they are actually overtightening if not using a torque wrench. This mostly applies to larger lugs like on a 200 amp connector. For your 30 amp and smaller connections that are typically being made with a screwdriver, you are more likely to find many of them are not quite as tight as recommended torque. A breaker that recommends 20 in-lb, about makes you think you are goint to break your wrist if you get that much out of a typical screwdriver one might use. Get a bigger handle or some other leverage and it is easy to overtighten it though.
Good point. If you read the comments under that video, few say that anyone should care if the work was done properly and that's par for most DIYs. The girl herself though actually says that if a qualified EC was willing to show her where she went wrong she would be willing to learn. That's a good quality.
-Hal
I spent 6 years in college taking up electronics engineering degree. Some of my school mates went to work in the US, one with NASA. But I didn't continue with the profession because halfway I got interested in medical. In electronics. We had AC subjects but we focused mostly on DC. So learning about electrical now is just kinda justifying spending 6 years in college and wasting those years and not applying it afterwards.
Because there is no excuse for using the "wrong" color when installing individual conductors, unlike cable assemblies where the rules make allowances for the way cable assemblies are manufactured.But lets gets get real. If white can be re-identified as hot coming out of a cable assembly, whats wrong with doing it with bare THHN?
Unless, of course, you already do understand this, in which case, I'll simply say, "never mind."I also presume you meant individual conductors, and not actual "bare" THHN (which wouldn't really be THHN, would it?)
As a generalized question, you could ak the same thing about half of the NEC. Specifically, it has to do with relying on a white conductor being grounded, and anything else (excluding green) being energized.What risk to human life and property exists with a 600 volt rated conductor being white?
See above comment. To answer you, yes, the white should be re-identified.What if I have a 150 foot run going from 120 to 240?
It is good quality for DIY, thats for sure.
But lets gets get real. If white can be re-identified as hot coming out of a cable assembly, whats wrong with doing it with bare THHN? Yes I know your not supposed to, but I've seen it done even by professionals, most of whom don't re-identify NM and MC either.
"What risk to human life and property exists" if every conductor was black?
A water heater or AC compressor doesn't care what colors the wires are, but a novice might presume they're only 120v because there's only white and black.
When someone assumes the white is a neutral when it really has 120V to ground on it.
-Hal
I'm going to say you are gifted, high IQ, and don't realize it. I've seen nothing unintelligent from you, on the contrary you are better at absorbing knowledge, making connections and asking relevant questions then I am.
The questions and comments were mainly rhetorical.Never assume a white is grounded or not energized, because if it breaks anywhere in the circuit that goes out the window. Hence the 600 volt insulation mandate in the NEC for neutral conductors.
Becomes more difficult for an electrician to identify the right conductor for ground. Wiring hundreds of devices in building increases the chance for a live hitting the ground screw.
Then said novice should not be doing electrical.
Then you should not be doing electrical work IMO. Any electrician knows that when they see white, there is a possibility its used for 240.
I made wrong career choices. When I found out in college no electronics can equal the nano size of cells and the brain. I became interested in medicine. But too late to transfer. So I just slept my way through college. Later when I found out our body has connection to physics beyond the standard model via qualia which has nonphysical source (in the Philippines we treat victims of possession at will and can even create it at will). Then i became interested in physics. But it's too late to get a degree of it (my dream was to get Ph.D in physics). Whatever, If you will read Sabine backlog. You will keep hearing about her saying physics was lost. No major discovery since the Higgs and all the predicted particles don't come true (the LHC Nightmare Scenerio has Come True). See http://backreaction.blogspot.com/2016/08/the-lhc-nightmare-scenario-has-come-true.html
[/QUOTE]She has even written a book called "Lost in Math". Also some physicists were transferring to the finance or banking division where things are more certain. Some may even go into electrical engineering which is definite. I think the new physics involves the understanding of our very qualia and extensions to it. This is what I'll focus on in months and years ahead. This is why I have to move on from all this electrical thing now. Thanks so much for all your help and nice things to say to encourage amidst all the darkness in the world.
Of course, we seasoned professionals know better than to make presumptions.
Yahhh, no major discovery because people like you are not given a fair chance. College should have seen your gifts and done anything everything to progress them instead of punishing you.
Its not your fault, its the system.
Well, where ever you go, you will progress it by leaps and bounds. :happyyes::happyyes::happyyes:
Unless there is evidence of loose connection, you should not re-tighten/re-torque aluminium/copper conductor connections.![]()
Thanks to those who recommended the alumiconn and torque screwdrivers. They are coming on Friday.
