- Massachusetts
So long as the conduit is not damaged, the means is irrelevant.
The addition of the language adding the 'equipment shall be identified for the purpose' is not providing any additional protection from damage. It's also so vague that it's nearly impossible to define.
I have used Iwire's board and screw method. It works great. I have used heat guns. They work great. In a pinch, I have used torches. Not so great, but if there is no hurry, good bends can be made with them.
Years ago, I was challeged by an inspector to heat PVC with a torch enough to bend without damaging it. I did it as he watched. Patiently.His response was 'good job'. We got our sticker and a lecture about making sure we didn't char the conduit if we used a torch.
'Identified' simply means it looks like it will work. Stupid rule.
So you either cannot or simply refuse to answer the question.
That's fine.
