- Massachusetts
crossman said:Not to sidetrack things, but "near the bottom" is unenforcable code anyway. What is near?
Start you own darn thread. :grin:
(and yes I agree with you)
iwire said:For those that do not know CEE is short for Concrete Encased Electrode.
In my opinion it is a NEC violation to stub the rebar out of the foundation for connection to the GEC.
The facts as I see them.
250.52(A)(3) defines what a CEE is. That description requires that the CEE be surrounded by at least 2" of concrete.
Given that definition the rebar that is stubbed out is not a CEE. It is simply a steel conductor attached to the the CEE so in reality the stubbed out section is a GEC.
250.62 prohibits using steel as a GEC.
In my opinion and due to 250.64(A) the only legal way to connect to a rebar CEE is with a copper conductor connected to the rebar in the area defined by 250.52(A)(3).
All you 'stubbers' are in violation of the NEC. :grin:
paul said:I'm thinking you've got too much time on your hands. :grin:
Now....if you can tell me how a stubbed out rebar attached to the GEC is somehow unsafe or less safe than attaching in the concrete, electrically unsafe(impalement safety doesn't count as that's building code), then I might buy into your over thought argument.![]()
crossman said:Paul:
Tens of millions of dollars are spent each code cycle precisely on the wording of the code. It is pretty darned important. Plus, some folks may enjoy exercising the cerebral matter along these lines.
right now, I am at my workbench working on one of my other hobbies, at the same time I am viewing the forum and thinking about the NEC. I am enjoying myself.
Now, I don't particularly have a problem with a stubbed out rebar. But shouldn't the code text mean what it says and say what it means?
Concerning the "too much time on my hands" about picking apart the code text, well, in a future life, I should probably be a lawyer.
iwire said:Who said this thread has anything to do with electrical safety. It is mostly a wording issue.
paul said:I see you missed the :grin: in my post.
As long as you are moving "A", make sure you move it down to the point where the dirt begins.iwire said:As to your graphic, I would move point 'A' 2" into the concrete. Once that is done everything from 'A' into the cement may well be a CEE. Anything from 'A' to the panel has to be a GEC.
mivey said:As long as you are moving "A", make sure you move it down to the point where the dirt begins.
chevyx92 said:This whole thread is moot. Nowhere in the article does it say where you can or can't attach to it.
Bob just tells you his perspective on it and you think it's code.
Just cause a portion is left in practicality so you can ground to it doesn't take away from the ground it has established already in the concrete and earth.
Come on people this is 2008 and how long has this code section been in effect?
There's always gonna be someone trying to dispel something.
iwire said:So how far can I run that stub? 18"? 24"? 30'?
crossman said:Dang it, gentlemen, some of you are just not getting it. This thread isn't about what your inspector allows. This thread isn't about what you consider to be safe. This thread isn't about how you do it. This thread isn't about your municipality's local ordinances. This thread isn't even about what is practical and safe. This thread is about WHAT THE CODEBOOK SAYS.
And if you read 250.52(A)(3) very carefully, you will see that the original post in this thread is correct.
e57 said:Yours and Bob's are but one take on it.
e57 said:I have, and I am sure that is what everyone who dared to post here is talking about - the code - and the many interpations of what it says. Yours and Bob's are but one take on it. Please explain your take on 250.68 in this context.
And I do not think I am alone either - would you say that the code is subject to interpetation? I can run SEC ~40' into a building, can you? Cavie and the many other "Stubbers" you have taken issue with can stub-up due to the interpetations of thier inspectors. Because you think you are right does not make it so in this situation, and promoting the idea that you are with your very respected position on this and many other forums will still not make you RIGHT - just opinionated.....iwire said:Now go back and look, there are many who agree with croosman and myself.![]()
crossman said:2008 NEC 250.68(A) Exception #1 is in the code expressly because the CMP realized that the CEE connection would have to be embedded in concrete.... that the electrode does not extend out of the concrete.
