jaylectricity
- Massachusetts
- licensed journeyman electrician
Maybe not, but then maybe the service riser is also in bad shape. There's an argument as to whether you're replacing the service or not.It may be different if your area, but a meter socket isn't considered service equipment per the NEC. If it's strictly a meter socket change out, you shouldn't have to install the emergency disconnect.
Sent from my SM-G781U using Tapatalk
I've won a few arguments with inspectors that I had to remind them about on later inspections, but sometimes it's not worth it.
