Iwire, upon examining your proposed definition change for "outlet".
1] Every junction box with joints and or a pull loop and blank covers would not be junction/pull boxes, but "outlets?
2] Therefore if this mentioned inspector was to prevail, then you would have to install receps and lights at every capped box according to your new definition. Every box/outlet in an installation must be designated and a device installed.
3] Electricians would not be able to distinguish between a pull/junction/outlet box. Outlet being where a device is installed.
4] What would you then term these boxes one from another?
I agree with charlie b here.
An outlet is where a device is insatlled per definition.
2005 Hanbook with commentary.
Device. A unit of an electrical system that is intended to carry or control but not utilize electric energy.
The definition of device was revised and made a bit broader for the 2005 Code. Components (such as switches, circuit breakers, fuseholders, receptacles, attachment plugs, and lampholders) that distribute or control but do not consume electrical energy are considered devices. Devices that consume incidental amounts of electrical energy in the performance of carrying or controlling electricity are now also considered devices. Some examples of these components include a switch with an internal pilot light, a GFCI receptacle, and even a magnetic contactor.
A capped junction/pull box" has nothing coming "out" from it. Nor can anything come out without a device as per described above.
