mivey
I never said that. That's why I thought you were yanking my chain.iwire said:I was not and it is, but your posts seemed to indicate you did not consider it as an issue.
tryinghard said:
to which I responded:tryinghard said:How many #12's will you install in a 3 gang switch box...
From my perspective, I thought I had already indicated I was aware of the box size needs. So when you posted this:mivey said:...As many as I need?...If the box is the right size...
It sounded sarcastic to me. I was not offended. I don't mind a little chain-yanking.iwire said:It appears from your posts that you are unaware of NEC box sizing requirements
tryinghard seemed to be making a case that my box size was restricted:
tryinghard said:If you have a standard 3 gang switch box that is 44 CI
And he made this comment which, to me, appeared pompous and condescending:
tryinghard said:Oh I know how to calculate wirefill for boxes, I don't think mivey relizes how easy it is to overfill one; do you?
then he tried to make this point which seemed to indicate that overfilling a box can be a problem for #12 but not for #14:
tryinghard said:And I'm trying to point out how easy it is to over fill a box by those who won't use 14
Again, I thought I made the point that it did not have to be about the wire, it could be about the box size:
mivey said:Well my friend, that's why they make more than one box size.:roll: If I'm doing re-work and need a bigger box, I put one in. If it is new work, I put whatever size box I need. What in the world is wrong with that?:-?
To which trying hard replied:
Which seemed even more condescending. I'm not saying he was being condescending, only that it sounded that way to me. I've apologized to tryinghard if I offended him and I would have apologized if I sounded condescending to him as well. That was not my intent. I was just bantering over the point that he was trying to make that it was about the wire and I was trying to make it about the box.tryinghard said:You still have not answered my question for a 3 gang box
I was refusing to help him build his own case because I did not agree with where he was going. It sounded like he was going down the path of "#14 allows you to not worry about the box fill calculations" and I was refusing to be led down that path, condescension or not.
