- Licensed Electrician
So you are okay with a recpt powering a sewer lift in a basement needing gfci protection but you don't think the same recpt in a plastic box out in the back yard needs to have it?Yes, that would be correct. Different set of premises from Al's.
That is a defined area in an interior location.
Al is trying to redefine a listed enclosure interior by using a definition from a source that explicitly says which documents it applies to. His definitions from that glossary do not list the NEC for those terms.
My point for the general usage is that a person has to intentionally modify the conditions of the install in order to create a hazardous condition.
Think of it like this.
If someone opens a window into your front room and plugs in a tool while standing outside, are you required to install a GFCI? No. The room did not magically become an exterior location.
That person modified the conditions. He is exposing a dry interior and using the receptacle in a way it was not intended. The receptacle was for table lamps and such in the room and not a pair of hedge clippers.
