- New Jersey
- Journeyman Electrician (retired)
So if there is one CEE which is made by installing 20' of bare #4 in the footing can that be used as the auxiliary electrode and not part of the GES? That would be the same as installing a ground rod electrode as the auxiliary, but since both types would be present and they would be required to be connected to the GES.That’s exactly how I read that as well . Multiple cee’s available only one of them is required to be connected to the GES , so if theres multiple only one is required to be a part of the GES, you can call/use the other ones as auxiliary grounding electrodes whether they tie to the GES or simply connect to a egc . But if there’s only one present it must be a grinding electrode that is bonded into the building’s GES , that’s how it reads to me
