M. D.
iwire said:But if the HO wants to do something that involves my being less then truthful to the inspector I would have no part of it.
I agree and have felt that pressure ,..not fun.
Jim W in Tampa said:Problem here is we have not seen this job.Usually i dont take the inspectors side,but here if he has no print saying what room this is in then its his call..
joebell said:MD
I have read your earlier post where you added the state building code section, but it seems to me that if there was a set of engineered (stamped) drawings for the job wouldn't the Architect define the space. Wouldn't the architect be the HO agent?
Joe
mkgrady said:The home owner added a granite shelf to what is being called a foyer which is next to the new kitchen I wired. ......
The inspector is requiring a counter top recept because he claims it's a kitchen counter.
. I am hoping to convince the inspector that it is not a counter and or it is not in the kitchen.
...... on your way to the kitchen you pass the shelf on your left, ...... As you pass the end of the shelf you enter the kitchen.
Any ideas on how to change the inspectors mind?
Mike
benaround said:IMO, Removing the 'shelf' is the worst option you could take. If you feel
100% sure that you are right, then stand up like the man you are and with
all the ammo this Forum has provided, politley and professionally present it
to the EI. If he can't prove his position but is to stubborn to change his
view, go to his boss.
all the ammo this Forum has provided, politely and professionally present it
mkgrady said:That's my plan
crossman said:Mike, whatever happens, please keep us posted about what happens!
Considering that the inspector has already seen the shelf, it is best not to remove it......
If I'm sure I'm right, I have no qualms about climbing the food chain. I'm not there to stroke his ego. Let's not forget that it takes two to have a disagreement.M. D. said:I hope you will consider the reaction ,.. I don't know you or your inspector or if you will work in his area often ,.. but most folks don't care for it when you go over their head..
Only a phone call to get his boss out the next day, and I was still on the job anyway, so maybe 20 minutes or so. Honestly.M. D. said:Larry how much time / money / effort was involved in resolving your latest disagreement ,..be honest now,...
So does having to add a receptacle after construction that (a) the NEC does not require, (b) the customer does not want, and (c) I wouldn't want to install because I love being right.and having to climb the food chain because you suspect there might be pay back is sort of what I'm talking about....It costs money
(edit to add)
M. D. said:Why ?? are we not free to decide if we do or do not want,.. a shelf in our homes??? and for that matter when or why we want it removed????
This is just ,....total bovine excrement!!
LarryFine said:Only a phone call to get his boss out the next day, and I was still on the job anyway, so maybe 20 minutes or so. Honestly.
Plus, (d) simply relenting sets a bad precedent (and it could be bigger and cost more next time), (e) an inspector who is never challenged thinks he's infallible, and (f) I love being right.
M. D. said:Show him this , straight from the 7th edition of the State Building Code
Question 7: 780 CMR 3603.16.13 requires that an existing one- or two-family dwelling be provided with
a household fire warning system for new construction when one or more sleeping rooms are
added or created in the existing dwelling. What constitutes a bedroom under this Section?
Answer 7: The State Board of Building Regulations and Standards (BBRS), as the Agency
promulgating the Massachusetts State Building Code, is the ?AUTHORITY HAVING
JURISDICTION? (AHJ) regarding the interpretation of regulations of the State Building
Code and has determined that it is the responsibility of the building owner or the agent of the
building owner to identify any new or newly created bedrooms or other space USES. If
submitted plans and/or narratives that describe the work intended identify such new additions
or newly created spaces as other than bedrooms then 780 CMR 3603.16.13 does not apply
(note that it is the ?REGULATED COMMUNITY? and not the ?REGULATOR? who
identifies, on plans and/or narratives submitted as part of the building permit application to
the Building Department, if a bedroom is being added or created).
M. D. said:What I am saying is ,..there are plans,... find out what they indicate the space as ,..If there is no detail for this space it is the H.O. that decides what to call it ,..not the inspector. They obviously do not view it as a kitchen space. A dwelling requires a "kitchen" ,..but how big it is and what shape it takes,. is up to the H.O. to a large degree.
I had a sister that once rented a two room apt. there were several spaces ,. kitcken , living ,and sleeping spaces , no interior walls , no doors ,.except for the bathroom and entrance , was it all a kitchen ,...was it all a sleeping area ???
I wonder how this inspector would like it wired??
iwire said:I don't see anything that says a counter in a kitchen that is not intended for food prep is not a 'kitchen counter'
If it is a counter top and it's in the kitchen it is a kitchen counter top regardless of it's intended purpose.
The problem in my mind is defining where a kitchen ends and 'other' begins with open home designs.
You have no obligation to be less than truthful, and I don't think you should. There is a difference in breaking rules and working around the rules. The homeowner did not want a receptacle there, and you told them that the shelf would require one, so they decided they did not like the looks of a shelf with a receptacle, and decided to have to shelf removed.iwire said:I pretty much agree there, what the HO does before or after I am there is really none of my business. But if the HO wants to do something that involves my being less then truthful to the inspector I would have no part of it.
