Coppersmith
- Tampa, FL, USA
- Electrical Contractor
The breakers are not in parallel, unless their load sides are connected together.
The equipment circuit drawing is probably referring to the location that needs to be used with a back-fed main breaker.
I was not referring to a "parallel breaker" per the NEC definition. I used the the more generic "breakers are in parallel" referring to the breakers being parallel on the line side. Since they are parallel on the line side, the main does not control the breakers below it. But I can see your confusion and I agree they probably meant that is where a backfed main should go due to the tie down location. The manufacturer should have been more specific in their language.
